Saving Model Files
  1. From the File menu select Save > Model.
    Or
    From the Home tools, Files tool group, click the Save Model tool.
    Note: If the model in the data base is a new model, a dialog will be displayed. However if the model already has a file name, it will be saved directly (no dialog will be displayed).
  2. From the Save As Model dialog, specify a file name and click Save.
    The model is saved.
