View new features for HyperWorks 2021.1.
HyperMesh composites modelings.
MotionView is a general pre-processor for Multi-body Dynamics.
Create and edit systems, assemblies, and analyses, use wizards to build models quickly, create and edit belt/pullies, NLFE stabars, and NLFE springs, access the EDEM and Track Builder tools.
Create and edit points, bodies, lines (curve graphics), solids (graphics), markers and vectors, edit grounded/ungrounded bodies, create and edit rigid body groups, configure gravity, and select material properties.
Create and edit various model entities.
Create and edit outputs, create and edit templates, run the solver, view reports, access the Load Export utility, use the Optimization Wizard, open HyperStudy, utilize many pre-processing and post-processing capabilities with regards to flexible bodies (or flexbodies), run MS/EDEM cosimulation in batch mode, and generate H3D from EDEM.
Use the Outputs tool to create a result output request to the solver, which writes out the requested data for plotting data.
Use the Templates tool to create and edit blocks of text that contain data fields and programming instructions.
The Run Solver tool allows you to either run the current model or run an existing solver command file generated previously by MotionView.
The View Reports dialog displays a report list of all reports generated from an analysis task run.
An external module invoked from MotionView. This module allows you to take loads from an ADAMS run and create a tabular summary file or a Nastran input card for those loads.
In the 2021.1 release, MotionSolve has new capabilities for optimizing multibody systems.
HyperStudy allows you to perform Design of Experiments (DOE), optimization, and stochastic studies in a CAE environment. It allows you to study the different aspects of a design under various conditions, including non-linear behaviors. It can be applied in the multi-disciplinary optimization of a design combining different analysis types.
The FlexBody Prep wizard allows you to create the flex H3D file from several sources, including an ADAMS MNF file, a NASTRAN PCH file, and a mirrored H3D file. You can also generate an H3D file using OptiStruct, a finite element analysis solver.
Generates ADAMS output files from a flexbody transient run, which can then be used in nCODE Fatigue software.
This tool helps to run the cosimulation in batch mode.
This tool helps to convert EDEM particle simulation results to animation H3D that can be visualized in HyperView.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
From the Preferences menu, you can access the Options dialog.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
(located in the lower portion of the window).
