Use Math as a Data Source
- From the Define panel, under Source, select Math.
- Define the vector using the curve calculator to create a mathematical expression.
View new features for HyperWorks 2021.1.
HyperMesh composites modelings.
Learn how to maninpulate plot data using the Plot Browser and other user interface tools and options.
Edit existing curves and add new curves to the current plot.
Add horizontal and vertical datum lines to plots.
Displayed immediately upon curve selection, the tip-to-tail function calculates and draws the tip-to-tail function based on the current plot.
ON THIS PAGE
ON THIS PAGE
