From the HyperGraph menu, select Vector
Chart to display the Vector Plot ribbon.
Figure 1. Vector Chart Ribbon
Define
Edit existing curves and add new curves to the current plot.
Datums
Add horizontal and vertical datum lines to plots.
Tip to Tail
Displayed immediately upon curve selection, the tip-to-tail function calculates and draws the tip-to-tail function based on the current plot.
