Deterministic Optimization
Set up a deterministic optimization and execution defining the objective of decoupling rigid body modes, creating constraints for rigid body mode frequencies, and specifying design space for variables in terms of mount stiffness, locations, and inclinations.
Specify design space for design variables.
Figure 1. Mount Optimization Utility - Study Tab - Determinisitc Optimization sub-tab - Des. Vars.
Define the objective for the rigid body mode decoupling criteria.
Figure 2. Mount Optimization Utility - Study Tab - Determinisitic Optimization sub-tab - Objective
Create constraints for rigid body mode frequencies and submit an optimization run.
Figure 3. Mount Optimization Utility - Study Tab - Deterministic Optimization sub-tab - Constraint
From the Display tab, display and compare rigid body mode frequencies and kinetic energy, baseline vs. optimized. A comparison review is shown of the design variables, optimized vs. baseline. You can save the configuration file with optimized design variables for further studies.
Figure 4. Mount Optimization Utility - Study Tab - Deterministic Optimization sub-tab - Display
