Change the Attributes of an Axis
- Select an axis from the current window.
- Right-click and select Edit to display the Entity Editor.
Or
- Double-click on the axis to display the Entity Editor.
- Modify the attribute(s).
View new features for HyperWorks 2021.1.
HyperMesh composites modelings.
Learn how to maninpulate plot data using the Plot Browser and other user interface tools and options.
The HyperGraph Plot Browser is located in the tab area sidebar and allows you to view the HyperGraph plot structure.
Use the floating Entity Editor to edit attributes for plot entities.
Use the entity selector to specify the plot entity to select.
Use the View toolbar to control the view and display of your plot.
Set default parameters for HyperGraph plot types.
From the HyperGraph modeling window, right-click to display HyperGraph context menus.
Axis attributes, such as labels, color, and scaling, can be edited using the Plot Browser, Entity Editor, or the Axes right-click context menu.
Using the Convert Axis Units dialog, you can convert the current unit of measure of a horizontal or vertical axis to another unit of measure.
The Synchronize Windows feature allows you to manipulate multiple plots in multiple windows at the same time.
The Vehicle Safety Tools (VST) is a collection of over 200 macros, Templex functions, and external functions for use by a vehicle safety engineer.
Or
