Defining Solution Coefficient Data from File
Import solution coefficient data (multi-frequency or single frequency) from a .sol file to create a solution coefficient data definition. Use the solution coefficient data definition when defining a solution coefficient source.
Note: Export surface currents on specified structures to a .sol file using a domain decomposition request.
  1. On the Construct tab, in the Define group, click the  Field/current data icon. From the drop-down list select  Import solution coefficient data from file.
    Figure 1. The Import solution coefficient data dialog.
  2. In the Solution coefficient data (*.sol) file field, browse to the file location.
  3. Specify the data block to be used:
    • To select data from a multi-frequency .sol file, select the Use all data blocks check box. The data is interpolated for use at the operating frequency.
    • To select data at a specific frequency in the .sol file, clear the Use all data blocks check box and enter the number of the relevant data block.
  4. In the Label field, specify a unique label for the solution coefficient data.
  5. Click Create to define the spherical modes data and to close the dialog.
