Field/Current Data
Define field or current data using either far field data, near field data, spherical mode data or PCB current data. Use the field/current definition when defining an equivalent source or a receiving antenna.
- Create a field/current definition
- Create a field/current data definition by defining the field data manually or by importing the field/current data from a file. A range of file formats is supported.
- Define an equivalent source or receiving antenna
- Use the field/current data definition to define an equivalent source or a receiving antenna.
