Rotating Geometry
Apply the rotate operation on the selected geometry part.
  1. Select the geometry part that you want to rotate.
  2. On the Transform tab, in the Transform group, click the  Rotate icon.
    Figure 1. The Rotate dialog.
  3. Under Origin, specify the origin for the rotate operation.
  4. Under Axis direction, specify the direction of the axis around which the rotation will take place.
  5. In the Angle [degrees] field, specify the rotation angle in degrees.
  6. Click the OK to rotate the selected geometry part and to close the dialog.
