Wire Ports
Wire ports can be applied to wires (geometry), mesh segments or on a vertex between segments.
- a wire or mesh segment is connected to a structure and the phase difference from the end point to the first segment centre results in a significance effect on the input impedance.
- a wire or mesh segment is connected between an infinite ground plane and an UTD plate.
![](../../../../images/feko/user_guide/cadfeko/image_port_wire.png)
Figure 1. A wire port on a segment (on the left) and a wire port on a vertex (to the right) in the 3D view.
