Solving a Region with FEM
To solve a model with the finite element method (FEM), you must activate FEM for each relevant region.
- Select the region (or regions) in the in the 3D view or in the details tree that you want to solve with the FEM.
- In the details tree, from the right-click context menu, select Properties.
- On the Region properties dialog, click the Solution tab.
- Under Solve with special solution method, from the drop-down list, select Finite Element Method (FEM).
- Click OK to save the region properties and to close the dialog.
