Edges and Wires (Geometry)
Edges are the boundaries of faces. Wires are not associated with faces and are often referred to as “free edges”.
![](../../../../images/feko/user_guide/cadfeko/tree_details_edge_select.png)
Figure 1. Select an edge in the 3D view to highlight the corresponding entry in the details tree. The converse is also true.
- Local mesh size
- Local wire radius
- Wire core medium (metallic, layered dielectric, impedance sheet)
- Coating (layered dielectric)
- Local mesh size
- Solution method
