Moving a Part into an Existing Assembly
Move a selected geometry part of mesh part into an existing assembly.
  1. Select the geometry part or mesh parts that you want to move into in an existing assembly.
  2. From the right-click context menu select Assembly > Move to.
  3. From the drop-down list select one of the following:
    • To create a new assembly, click (new).
    • To move the selected part into an existing assembly, select an assembly.
