Field Data Configuration
Set up the field data configuration table to be used with the measurement method to map to the correct near field or far field data (available under Stored data in the .pfs file).
fieldDataConfiguration = {}
-- Specify the Far field data
-- Note the label should match the stored data in the .pfs file.
fieldDataConfiguration["FarFields"] = {}
fieldDataConfiguration["FarFields"][1].Label = "FarField_1"
fieldDataConfiguration["FarFields"][2].Label = "FarField_2"
fieldDataConfiguration["FarFields"][3].Label = "FarField_3"
fieldDataConfiguration["FarFields"][4].Label = "FarField_4"
-- Specify the Near field data
fieldDataConfiguration["NearFields"] = {}
fieldDataConfiguration["NearFields"][1].Label = "NearField_1"
fieldDataConfiguration["NearFields"][2].Label = "NearField_2"
fieldDataConfiguration["NearFields"][3].Label = "NearField_3"
fieldDataConfiguration["NearFields"][4].Label = "NearField_4"
