Adding Variables
Define variables to create a parametric model.
A model is parametric when it is created using variable expressions. When a variable expression is modified, any items dependent on that variable are re-evaluated and automatically updated. It is the recommended construction method when creating a model, but not compulsory.
Defined variables are stored as part of the model in the .cfx file.
  1. Open the Create variable dialog using one of the following workflows:
    • On the Construct tab, in the Define group, click the  Variable icon. From the drop-down list, select the  Add variable icon.
    • On the model tree, a right-click context menu is available on Variables. From the drop-down list, select Add variable.
    • On the model tree, click the icon. From the drop-down list, select Add variable.
  2. Create the following variables:
    Name Expression
    alpha 60
    alpha_rad alpha*pi/180
    d 0.25
    lambda 1
    freq c0/lambda
    Tip:
    • Click Add to keep the Create variable dialog open and add more variables.
    • Click Create to add a variable and close the Create variable dialog.
