Specifying the Optimisation Parameters
Specify the optimisation parameters. Choose from existing variables and specify their minimum and maximum values
  1. In the model tree (Construct tab), select the relevant search. On the Request tab, in the Optimisation group, click the  Parameters icon.
  2. On the Optimisation parameters dialog, click the Add button to add a second parameter.
  3. Populate the fields on the Optimisation parameters dialog as given in the table.
    Variable Min value Max value Start value
    alpha 20 110 80
    d 0.7 0.9 0.8
  4. Click OK to set the parameters and to close the dialog.
