Setting the Simulation Frequency
Specify the frequency range of interest. For this example a single frequency point is used.
  1. On the Source/Load tab, in the Settings group, click the  Frequency icon.
A variable was created at the beginning of the example that contains the solution frequency.
  1. In the Frequency (Hz) field, enter freq.
  2. Click OK to set the frequency and to close the dialog.
    Note: With the frequency set to freq, the actual frequency is 299.792 MHz. In the model tree, click the Configuration to view the specified simulation frequency.
