Creating the Port
Define a wire port on the feed pin to excite the dipole. A voltage source will be added to this port.
  1. Select Bent_dipole and its corresponding wire in the details tree.
  2. Define the wire port on the selected wire using one of the following workflows:
    • On the Source/Load tab, in the Ports group, click the  Wire port icon.
    • In the details tree, a right-click context menu is available on the wire. From the drop-down list, click Create port > Wire port.
  3. Under Place port on, click Vertex.
  4. Click Create to create the port and to close the dialog.
    Note: These steps should place a port at the centre of the dipole in the 3D view.
