Export cluster, profile and application definition information to a zip
file.
Create a zip file containing cluster, job profile and
application definition information. The zip file can then be used to install Access Desktop on other workstations eliminating the need to add clusters, job
profiles and application definitions at each workstation.
Open the Windows system tray.
Double-click the Access Desktop icon
Click
Select Export Config from the menu.
Select a folder where the exported configuration will be saved.
A zip file called AltairAccessConfig.zip is created in
the selected folder.
