Log into Access Desktop and Register an HPC Cluster
Log into Access Desktop and register an HPC cluster so that you can begin submitting jobs to the Workload Manager.
Launch Access Desktop
Launch Access Desktop so that you can submit jobs to the Workload Manager.
Add a Cluster Using SSH
Add and establish a connection to the HPC cluster using SSH by registering it so that you may begin submitting and monitoring jobs.
Add a Cluster Using HTTPS
Add and establish a connection to the Access Web server using HTTPS so that you may begin submitting and monitoring jobs.
- The URL of an Access Web server with a valid set of credentials to connect.
Login to Access Desktop to submit and monitor jobs.
Figure 3. Login Screen
