Application definitions are a predefined set of instructions to describe application parameters, store responses and
prepare responses for job execution.
Add a Cluster Using SSH
Add and establish a connection to the HPC cluster using SSH by registering it so that you may begin submitting and monitoring jobs.
Add a Cluster Using HTTPS
Add and establish a connection to the Access Web server using HTTPS so that you may begin submitting and monitoring jobs.
Edit Cluster Details
Update the staging location and the central repository server address details.
Delete a Cluster
Remove a cluster when you no longer want to submit and manage jobs on that cluster.
