Add and establish a connection to the Access Web server
using HTTPS so that you may begin submitting and monitoring jobs.
To add a cluster using HTTPS you will need:
- The URL of an Access Web server with a valid set of
credentials to connect.
This option uses HTTPS for all communication between Access Desktop
and Access Web.
Open the Windows system tray.
Double-click the Access Desktop icon
Click
Select Clusters.
A Clusters dialog box is displayed.
Select HTTPS using the drop down box.
For Cluster Display Name, enter a name for the cluster as it will be known
within Access Desktop.
Enter the Access Web URL in the format
https://<login node name>:4443 where <LOGIN NODE
NAME> is the host name of the machine where Access Web is installed.
For User name, enter your user name.
For Password, enter your password.
Click Add.
Tip: Repeat the previous steps to add an additional HTTPS
cluster.
Click Done.
The cluster is added successfully and it displays with a green tick
mark.
Click
on the top-right corner.
The application updates the server and the solver applications
automatically.
