Delete a Cluster Remove a cluster when you no longer want to submit and manage jobs on that cluster. Open the Windows system tray. Double-click the Access Desktop icon . Click . Select Clusters from the menu. A list of clusters that are registered and available is displayed. Figure 1. Clusters Find the cluster you want to remove and click next to its name. The cluster is removed.
