Disable the Copy Back Output Preference
Disable the copy back output files option.
By default, the copy back output option is enabled in Access Desktop.
If the Copy Back Output preference is disabled, then the job output files are stored in the login node until the files are copied to your system.
  1. Open the Windows system tray.
  2. Double-click the Access Desktop icon .
  3. Click .
  4. Select Preferences from the menu.
    A preferences menu is displayed.
    Figure 1. Preferences
  5. Move the Copy Back Output slider button from right to left.
  6. Click Apply.
  7. Click Done to close the preferences menu.
