Visualize Plots
You may visualize your results from the Files and Jobs tabs.
Access Web provides you an option to access output result files from the Files and Jobs tab. The job folders are created with a Job ID and hence it becomes easier to navigate and visualize the job results.
Choose your option:
  • From the Files tab, open the Job ID folder to select an output file that you wish to plot.
  • From the Jobs tab, here are the two options to visualize plots:
    • Click the Job ID which is in the running state, the Running Folder displays the processing job result files. Select a file that you wish to plot.
    • Open the Job ID folder from the jobs list, select an output file that you wish to plot.
