Add or remove access privileges for a role.
You cannot change the access privileges of the default roles.
Click the Configure tab.
Click Roles from the Access Management menu located on
the left-hand side of the web page.
Click the name of the role.
Choose one of the following options to change the privileges given to the
role:
- Click located to the right of the privilege to enable the
privilege.
- Click located to the right of the privilege to disable the privilege.
Privileges are not mutually exclusive, so you may assign more than one.
Click Save.
