User Interface
Visual guide of the SimSolid Cloud user interface.
Project Dashboard
Icon paletteProjectsProject action menuDetailed information panelAdd project button
  1. Icon palette - You can access to the Project dashboard, Project window, your account information, and help on the icon palette. Select the header to expand the icon palette.
  2. Projects - Projects are listed here. By default, only projects associated with the current geometry file are displayed. To see all projects, open the drop-down menu above the list of projects and select All projects. Pertinent data about the project is given in columns at the top. The columns can be sorted or dragged to reorder. Additional data columns can be added by selecting the pull-down menu found with each column header. Once you select a project, detailed information appears in the panel on the right. You can double-click on a project to open.
  3. Project action menu - Select (Project action button) or right-click on a project to access actions you can perform.
  4. Detailed information panel - More detailed information about an individual project is displayed here.
  5. Add project button - Use the Add project button to access the geometry file selector dialog. Select a document and then an element (Part or Assembly) to load the model and create a new SimSolid document.
Project Window
Project explorerPanelsModeling window
The Project Window is the primary application window. This is where you setup, run, and post-process your analysis.
  1. Project explorer - You can access panels for the current project here. Select the title bar to open or hide the project explorer.
  2. Panels - Assembly, Connections, and Analysis panels are where you configure your analysis. You can select the header to open and close a panel. In the panel, you can select column headers to sort, or drag columns to reorder. Select (Entity action button) to perform actions on individual entities. You can also multi-select entities with Shift + Control.
  3. Modeling window - The model is displayed here. You can select and interact with parts, change display options, and change views in the modeling window. Use the mouse for model manipulation and object/dialog list selection. For information about mouse controls, go to Mouse Controls.
    With a few limitations, you can also use touch screen monitors with SimSolid Cloud. For more information, go to Touch Screen Monitor Controls.
Change Model View
View the model from different standard views available in SimSolid Cloud.
The following model views are available: Top, Bottom, Front, Back, Left, Right, and Isometric.
  1. On the icon palette, click Project.
  2. Change the orientation of the model in any of the following ways:
    OptionDescription
    Use the View menu
    1. In the modeling window, click the Views button.
    2. Select the desired view from the drop-down menu.
    Use the coordinate triad
    Click any of the block faces to snap that plane parallel to the screen. Double-click to rotate 180 degrees.
    Define the Top view
    1. On the icon palette, click (Settings).
    2. Click the Appearance tab.
    3. For Standard view defaults, select the desired option.
Change Display Options
Choose how parts are displayed in the modeling window.
  2. In the modeling window, click the Display Options drop-down menu.
  3. Select the check boxes for the desired views.
    The following display options are available:
    Show hidden parts as ghosts
    Shows hidden parts as transparent but not selectable.
    Show parts translucent
    Renders the model transparent.
    Show parts in random color
    Renders each part with a separate color.
    Zoom view to selected
    Automatically zooms view to the entities selected in the Project Tree.
    Show part edges
    Toggles part edges on and off.
    Show spots
    Toggles spot symbols on and off.
    Show boundary conditions
    Toggles boundary condition symbols on and off.
    Show seam welds
    Toggles seam welds on and off.
    Enable clipping plane
    Clips the assembly with a plane.
