Set Face Faceting Parameters
Set Face Faceting Parameters for analysis in SimSolid Cloud.
  1. In the icon palette, click Settings.
  2. Click the Geometry tab.
    • In the Resolution menu from geometry import settings, choose, Standard, Enhanced, or Fine. The values will automatically populate the Angular deviation and Chordal deviation fields.
    • In the Resolution menu, choose Custom. Then, enter the desired values in the Angular deviation and Chordal deviation fields.
  3. Click Save.
