Review Part Contact Conditions
Review contact conditions of connections in selected analysis.
- In the modeling window, right-click on a part of the model.
In the context menu, select Contact
conditions.
Note: This option is greyed out if no analysis exists in the project.A dialog opens and shows a list of all connections and contact conditions for the selected part and analysis. Contact conditions for specific analysis or all analysis can be edited from this dialog.
- In the drop-down menu, select an analysis to edit its contact conditions.
- Select a connection to see it highlighted on the model.
On the Connections workbench, next to the desired
connection select .
Tip: You can also double-click on the connection in the modeling window to edit.
- In the dialog, choose a contact condition type.
- Click OK.
- Optional:
Select the Connections between parts in list only check
box to only display connections between selected parts.
By default, all connections associated with both parts are displayed.
- Optional:
Select the Apply to all structural analyses check box to
apply changes to all structural analyses.
By default, only the analysis selected in the drop-down menu is modified.
