Thermal Contact Conditions
Apply thermal specific boundary conditions between parts in an assembly.
Two values are possible: no thermal resistance or insulated. No thermal resistance is the default condition and means that full heat transfer occurs through the part connection. Insulated means the opposite. No heat transfer occurs.
- In the Project Tree, click on the Thermal Analysis Workbench.
Click the
(Action menu) button beside the desired analysis,
then choose Contact conditions from the menu.
In the dialog, toggle either no thermal resistance or
insulated.
