Altair® Monarch®
Report Design
Report Design allows you to create or edit report templates. You go to this mode within Report View.
The Report Design interface has the following elements:
Element
[ 1 ] Ribbon
Displays all the tools you need to work with a report template.
Refer to the Report Design Ribbon Quick Reference
[ 2 ] Selector
Allows you to search for and/or select a specific template.
[ 3 ] Template Editor
Displays the currently-selected template.
 An action bar at the top of the Template  Editor provides  tools for defining template traps and fields.
[ 4 ] Preview Grid
Displays a sample of the data that will be extracted by the currently-defined templates. The Preview Grid provides quick feedback
[ 5 ] Field Properties panel
Displays the properties of the currently selected field on the Template Editor.
Going to Report Design
Select Report Design on the Report View ribbon.
Creating a template
  1. Select New Template from the Report Design ribbon.
  2. Select a template type.
  3. Define your traps and fields.
See Creating a Template for related information.
Selecting a template
To select a template, click the template on the templates selector:
If you wish to search for a template first, enter search criteria into the searchbox at the top of the templates selector.
Additional Report Design actions
From within Report Design, you can also do the following:
