Minimize Mass
Minimizing mass is one of several optimization objectives, and is available with topology, gauge, and lattice optimization.
Minimizing Mass for Topology Optimization
- Stress Constraints - applied using the Run Optimization window and specified in terms of a safety factor.
- Frequency Constraints - applied using the Run Optimization window.
- Displacement Constraints - applied using the
Displacement Constraints tool.Note: Once optimization is complete, the best result when minimizing mass is generally found by dragging the topology slider to the far right in the Shape Explorer.
Minimizing Mass for Gauge Optimization
- Displacement Constraints - applied using the Displacement Constraints tool.
Minimizing Stiffness for Lattice Optimization
- Lattice - applied using the Run Optimization window.
- Stress Constraints - applied using the Run Optimization window and specified in terms of safety factor.
Example 1: Minimizing Mass Subject to Stress Constraints
![](../../../images/inspire/brake_pedal.png)
Figure 1. Original Model
![](../../../images/inspire/brake_pedal_sc1.png)
![](../../../images/inspire/brake_pedal_sc2.png)
Example 2: Minimizing Mass Subject to Stress and Displacement Constraints
![](../../../images/inspire/brake_pedal_d2stress.png)
Figure 4. Displacement Constraint of 2 mm at the Foot Peg
![](../../../images/inspire/brake_pedal_d1stress.png)
![](../../../images/inspire/brake_pedal_nostress.png)
