Forces
A force is a push or a pull in a particular direction on a part, and is a type of load. Use the Apply Force tool on the Loads icon to apply a force.
![](../../../images/icons/inspire/icon_forces.png)
Forces can be applied to a point, edge, face, or hole center. Once applied, distributed forces on certain types of features can be converted to bearing forces or traction forces.
![](../../../images/inspire/forces_point_edge_surface.png)
Figure 1. Forces Applied to a Point, Edge, or Face
![](../../../images/inspire/force_at_hole_center.png)
Figure 2. Forces Applied to a Hole Center
Apply a Force
Select the Apply Force tool, click on a feature, and enter a magnitude.
- When created, forces are automatically assigned to the current load case.
- A distributed force acts in a single direction across the extent of an edge or face. You can change whether a force is distributed or not in the Property Editor.
- To apply a force that is perpendicular to a face at each point across its entire extent, like air pressure in a balloon, use a pressure instead of a force. You can also apply a force as a pressure if all you know is the magnitude of the force. Simply create a pressure and enter the magnitude in force units.
- Use the Property Editor to change the name, magnitude, mode, direction, and appearance of the force, and whether it rotates with the part.
Bearing Forces
A bearing force applied to a hole mimics the contact force between a shaft and a bushing.
![](../../../images/inspire/bearing_load_example.png)
Figure 3. Bearing Force Applied to a Hole Center
Click on
the microdialog to convert a distributed force to a bearing force.
Traction Forces
A traction force can be applied to a cylindrical face, and acts tangential to that face. This mimics contact forces between parts, such as friction.
![](../../../images/inspire/traction_force_2.png)
Figure 4. Traction Force Applied to a Cylindrical Face
Click on
the microdialog to convert a distributed force to a traction force.
Microdialog Options
Double-click a force arrow to enter editing mode, which opens the Force microdialog.
Convert to a distributed, bearing, or traction force. |
Change the direction of the force. |
Enter a magnitude for the force. |
Click the icon to orient the force to a local system. |
Click the icon to switch between direction force mode and component force mode. |
Create connectors to forces that have been moved away from the model. |
Translate or rotate the force using the Move tool. Use to place a force at a distance. |
Align the force to the x-, y-, or z-axis. |
Align the force normal (perpendicular) to the face. |
Align the force to the centerline of a hole. (This button only appears if the force is applied to the center of a cylindrical hole.) |
Click the chevron to orient the force by entering either a direction and magnitude (X, Y, and Z) or components (Fx, Fy, Fz). |
Mouse Controls and Keyboard Shortcuts
Ctrl | Apply the force to multiple features on the same part. |
Shift | Create a concentrated force at a point on an edge, face, or hole. |
Right-click and mouse through the check mark to exit, or double-right-click. | Exit the tool. |
