RD-T: 3000 Tensile Test Setup
This tutorial demonstrates how to simulate a uniaxial tensile test using a quarter size mesh with symmetric boundary conditions.
- UNITS: Length (mm), Time (ms), Mass (kg), Force (kN) and Stress (GPa)
- Simulation time Rootname_0001.rad [0 - 10.]
- Boundary Conditions:
- The 3 upper right nodes (TX, RY, and RZ)
- A symmetry boundary condition on all bottom nodes (TY, RX, and RZ)
- At the left side is applied a constant velocity = 1 mm/ms on -X direction.
- Tensile test object dimensions = 11 x 100 with a uniform thickness = 1.7 mm
| [Rho_I] Initial density = 2.7e-6 Kg/mm3 |
| [E] Young's modulus = 60.4 GPa |
| [nu] Poisson's ratio = 0.33 |
| [a] Yield stress = 0.09026 GPa |
| [b] Hardening parameter = 0.22313 GPa |
| [n] Hardening exponent = 0.374618 |
| [EPS_max] Failure plastic strain = 0.75 |
| [SIG_max] Maximum stress = 0.175 GPa |
Input file for this tutorial: TENSILE_0000.rad
Create and Assign a Material
Create and Assign a Property
- From the menu bar, select .
- Right-click in the property list and select .
- For Title, enter Pshell.
- For Shell Thickness, enter 1.7.
In the bottom of the property window, right-click in the
Support entry box and select the Include
picked parts icon
- Select the part in the modeling window.
- Right-click to validate the selection.
- Click .
Define Boundary Conditions Representing Symmetry
Define Imposed Velocity
Define a Time History Node
Export the Model
Expected Results
Figure 15. Total Displacement Contour (mm)
Figure 16. Plastic Strain Contour
to select the
nodes in the
, to select the nodes in the
to
add a new row.
