/IMPL/DT/STOP
Engine Keyword The computation will be stopped, if DT_min is reached. If DT_max is reached, the computation will continue with constant time step set as DT_max.
/IMPL/DT/STOP
DT_min DT_max
Data | Description | SI Unit Example |
DT_min | Minimum time step.
DT_max | Maximum time step.
