RD-V: 0520 Double Oblique Shock
A supersonic flow encounters two successive wedges and oblique shock are formed.
The double oblique shock is a classic example in compressible fluid mechanics. It involves a supersonic flow propagating along a wall with two unequal wedges. Each wedge slows down and compresses the flow with the formation of a shock wave. These two shocks then merge into a stronger, single one away from the wall, and a contact wave is formed inside the flow between the shocked states. The numerical results obtained for the thermodynamics quantities in each state of the flow can be compared to analytical values obtained with compressible fluid mechanics theory.
Options and Keywords Used
- Fluid material, /MAT/LAW6 (HYDRO or HYD_VISC)
- Multi-fluid law using the FVM solver, /MAT/LAW151 (MULTIFLUID)
- Ideal gas EOS, /EOS/IDEAL-GAS
- Second order integration scheme, /ALE/MUSCL
- Inlet boundary condition, /EBCS/INLET
- Outlet boundary condition, /EBCS/FLUXOUT
- Initial fluid velocity, /INIVEL/FVM
Input Files
- <install_directory>/hwsolvers/demos/radioss/verification/Blast/0520_double_shock/*
Model Description
A supersonic wind tunnel (100mm length, 50 mm height) is filled with a supersonic flow Machine number (M=3) of air.
The lower wall includes two wedges of 8 degrees and 28 degrees.
Figure 2. Problem Description for Double Oblique Shock
Units: mm, ms, g, N, MPa
Model Method
The fluid domain is meshed with 2D quads elements with an average mesh size of 0.15*0.15 mm. This accounts for around 160,000 elements.
The material law used for air is a hydrodynamic fluid (/MAT/LAW6) in combination with an ideal gas equation of state (/EOS/IDEAL-GAS).
The hydrodynamic fluid (/MAT/LAW6) is used within a multifluid law (/MAT/MULTILFUID) which uses a Finite Volume solver. The fluid is considered non-viscous.
- /MAT/LAW6
- Initial density
- 1.225E-6
- /EOS/IDEAL-GAS
- Heat capacity ratio
- 1.4
- Initial pressure
- 0.1 MPa
- Initial density
- 1.225E-6
Since there is only one fluid (air), the multi-material law only integrates the air defined using LAW6, with a volumer fraction of 1.
To indicate that it is an EULERIAN material, /EULER/MAT should be defined for the /MAT/MULTIFLUID material.
The /ALE/MUSCL option activates a full second order integration scheme in time and space. It should be added for more precision.
Boundary Conditions
Figure 3. Boundary Condition for Double Oblique Shock
When using /MAT/MULTIFLUID, the default boundary conditions are sliding walls.
A non-reflecting inlet is defined using /EBCS/INLET/VP. Input density and pressure are defined for the air in the multi-material law.
A non-reflecting boundary is defined with /EBCS/FLUXOUT.
Engine Control
As of the Radioss 2019.0 release, the critical time step scale factor for all ALE and EULER elements defaults to 0.5.
/DT/ALE
0.5 0.000000
Results
Figure 4. Contour for Elemental Velocity
Figure 5. Contour for Elemental Pressure
Figure 6. Schlieren Output to the Power of (5/density)
Figure 7. Shock Fronts and Density Map Showing the different States
Fluid particles close to the wall go through two shock fronts, while those away from the wall see only one. However, it is stronger, so flow quantities in State 3 differ from State 2. State 2 and State 4 are separated by a verification wave, with allows for a pressure equilibrium between States 3 and 4. All other quantities are otherwise discontinuous between State 3 and State 4, as the two are separated by a contact wave.
Results obtained from the simulation can be compared to the values obtained analytically.
Analytical Analysis
Figure 8. Deflection of Supersonic Flow through an Oblique Shock
The theoretical values of thermodynamic quantities in every state can be determined analytically.
All the physical properties in State 1 and State 2 can thus be determined.
The determination of State 3 and State 4 is more complex. Stage 3 is separated from State 0 by a single oblique shock wave. However, this shock wave is not generated by a single wedge of known angle, but rather by the combination from the two other shocks.
The pressure in State 2 and 3 is not the same because the flow went through two successive oblique shock waves, instead of through one stronger shock front. A verification process will happen after State 2 until the pressure has decreased to its value in the adjacent State 3.
State 3 and 4 needs to be determined together. State 3 is obtained from a flow initially in state 0 that encounters an oblique shock (which angle in unknown) and shares the same pressure that State 4. The State 4 pressure is obtained after an isentropic verification from State 2, in which the Mach number of the flow changes from to .
- Oblique shock of angle between State 0 and State 3.
Figure 9. Mach Value Contour . w/o possible node paths going through every state of the flow
- Isentropic verification process from State 2 to State 4.
With and determined, the other thermodynamics variables in State 4 are determined considering an isentropic rarefaction process from State 2 to State 4, and for State 3, by considering an oblique shock with an angle.
State 1 | State 2 | State 3 | State 4 | |
Shock angle [deg] | 25.611 | 41.582 | 48.586 | no shock |
Mach number | 2.603 | 1.722 | 1.537 | 1.746 |
Pressure [MPa] | 0.180 | 0.595 | 0.574 | 0.574 |
Mass density | 1.85E-06 | 4.15E-06 | 3.70E-06 | 4.04E-06 |
Numerical Results with Analytical Values Comparison
Numerical results for the thermodynamic variables can be read by drawing two node paths along two current lines, one close to the wall and going through State 1, 2 and 4, and the other further away from the wall, going from State 0 to State 3 (Figure 9).
To draw node paths, the elemental results visible on the animation have to be averaged at the nodes, using for example the averaging method simple.
Figure 10. Pressure Profile in Steady-State. with the value of the relative error to the analytical value
Figure 11. Mass Density Spatial Profile in Steady-State. with the value of the relative error to the analytical value
Analytical | Numerical | Relative Error (%) | |
State 1 | 2.603 | 2.607 | 0.14 |
State 2 | 1.722 | 1.717 | 0.32 |
State 3 | 1.537 | 1.529 | 0.56 |
State 4 | 1.746 | 1.746 | 0.05 |
The relative error between numerical and analytical values for pressure, mass density and Mach number are for every state inferior to 1%.
Conclusion
Supersonic flow is modeled using a /MAT/LAW6 hydrodynamic fluid law, associated with an ideal gas equation of state (/EOS/IDEAL-GAS), within a multi-fluid material /MAT/LAW151 to use the finite volume solver.
As the flows encounters two wedges, three stationary shock waves and a contact wave are formed within the flow. The value of the flow physical parameters in each state can be determined analytically.
The analytical approach shows a good correlation between theoretical and numerical results.
The shocks and contact wave are rendered well on the simulation. The use of /MAT/MULTIFLUID allows for an accurate modeling of the dynamics of supersonic flows.
