/@TFILE
Engine Keyword The time at which the time history file begins.
/@TFILE
Tstart
N1 N2 ... NN
Data | Description | Si Unit Example |
Tstart | Time at which the time history file begins to be written. | |
Time frequency to write data on file. | ||
N1 , N2 ... NN | List of nodes. |
- The name of the time history file is "Runname_0001@.thy".
- Only nodal velocities are saved in the file.
- When restarted if you specify the @TFILE parameters again (Tstart, , list of nodes and the variables), the filtering is reinitialized and this may result in a non-contiguous TFILE. For a clean restart, just specify /TFILE without any parameters at all.
