.h5 file
A binary file, containing model and result data.
File Creation
The .h5 file is created when the HDF5 format is chosen (FORMAT and OUTPUT).
File Contents
- Result
- Description
- Composite ply strain
- Ply strain results for composite materials from Linear Static, Nonlinear Static and Normal Modes analysis.
- Composite ply stress
- Ply stress results for composite materials from Linear Static, Nonlinear Static and Normal Modes analysis.
- Displacement
- Displacement results from Linear Static, Nonlinear Static, Normal Modes and Linear Buckling analysis.
- Element force
- Element force results from Linear Static and Normal Modes analysis.
- Grid point force
- Grid point Force results from Linear Static and Normal Modes analysis.
- Applied Load
- Applied Load Results from Linear Static analysis.
- SPC force
- Single-point force of constraint results from Linear Static and Normal Modes analysis.
- MPC force
- Multi-point force of constraint results from Linear Static and Normal Modes analysis.
- Strain
- Strain results from Linear Static, Nonlinear Static and Normal Modes analysis.
- Stress
- Stress results from Linear Static, Nonlinear Static and Normal Modes analysis.
- In case of Linear Static and Normal
Modes analysis,
- The supported element types for element-based results (in
.h5 format) are:
Result Elements Supported FORCE/ELFORCE CBAR, CBEAM, CONROD, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CSHEAR STRESS CROD, CBAR, CBEAM, CONROD, CELAS1, CELAS2, CBUSH, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CSHEAR, CTETRA, CHEXA, CPENTA STRAIN - Corner results are also available for the above results with CQUAD4 and CQUAD8 elements.
.h5 format) are:
- In case of Nonlinear Static
analysis,
- The supported element types for STRESS and
STRAIN results (in .h5
format) are:
Result Elements Supported STRESS CROD, CELAS1, CBAR, CBEAM, CTRIA3, CTRIA6, CQUAD4, CQUAD8, CHEXA, CPENTA, CTETRA STRAIN - Corner results are also available for CQUAD4 and CQUAD8 elements.
- DISPLACEMENT, STRESS and STRAIN results are also available on-the-fly during the analysis, if the NLOUT entry is defined in the subcase.
format) are:
- In case of Linear Buckling analysis, only DISPLACEMENT result is available in .h5 format.
