.HM.crtelem.cmf file
The .HM.crtelem.cmf file is a HyperMesh command file.
File Creation
The file is created when Nonlinear Explicit Analysis is run.
File Contents
This file contains a list of critical elements/nodes associated with the top “n” smallest elemental/nodal timesteps. The number “n” is controlled by PARAM,CRTELEM and the default is 10.
When loaded in HyperMesh, the .HM.crtelem.cmf file adds the elements/nodes into a set for further review.
