_s#_d.mbd file
The _s#_d.mbd file is an OptiStruct ASCII format results file.
File Creation
This file is only created for Multibody Dynamics subcases. Creation of this file is controlled by the I/O Option OUTPUT.
File Contents
Result | Description |
Displacement | Displacement results from
multibody dynamics analyses. Output is controlled by the I/O Option DISPLACEMENT. |
File Format
Time"X Trans"Y Trans"Z Trans
- The # in the file name is the user-defined subcase ID from which these results are obtained.
- The _mbd.mvw HyperView script file automatically creates plots for the results contained in this file.
