Kernel Parameters
The spline function used to interpolate quantities and derivatives is called a “kernel” in SPH. To define the kernel accordingly to the initial particle configuration the spacing needs to be set here.
kernel
      dx          	  0.1
dx
The initial particle spacing. This value is mandatory. Verify it is in agreement with the geometry input file. For example, the particles were created with the same initial spacing.
