OS-V: 0455 Simply-Supported Solid Square Plate
Test No. FV52 A well-established solid square plate, which contains three rigid modes with the given boundary condition. The test examines the performance of OptiStruct Normal Modes Analysis on 3D solid elements.
![fv52](../../../images/solvers/fv52.png)
図 1.
Benchmark Model
The HEXA 8-node and HEXA 20-node solid elements are used in test FV52. An 8x8x3 mesh configuration is used for HEXA 8-node elements, and a 4x4x1 mesh configuration is used with HEXA 20-node elements. The z-directional displacement is constrained at Z = -5m plane along the four edges of the plate.
- E
- 200 x 109 N/m2
- 0.3
- 8000 kg/m3
Modal Analysis Results
f*
- Closed form solution.
Mode 4 | Modes 5 and 6 | Mode 7 | |||
f* HEXA20 HEXA8 |
45.897 Hz 0.9760 0.9874 |
f* HEXA20 HEXA8 |
109.44 Hz 1.0101 1.0413 |
f* HEXA20 HEXA8 |
265.81 Hz 1.0072 1.0322 |
Mode 8 | Modes 9 and 10 | ||
f* HEXA20 HEXA8 |
193.59 Hz 1.0017 1.0164 |
f* HEXA20 HEXA8 |
206.19 Hz 1.0022 1.0164 |
Model Files
The model files used in this problem include:
- /fv52_HOE.fem
- /fv52_LOE.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
