OS-V: 0415 Deep Simply-Supported Beam
Test No. FV5 OptiStruct tests the repeated eigenvalues, shear deformation, and rotary inertia. The possibility of missing extensional modes is also investigated.
図 1.
Benchmark Model
The 2-node beam elements are used to model the simply-supported beam which consists of five elements. The displacements in x, y, and z direction, as well as the rotation in x direction are fixed at the end A. In addition, the displacements in y and z direction are constrained at end B.
The material properties are:
E
200 x 109 N/m2
υ
0.3
ρ
8000 kg/m3
Modal Analysis Results
The frequency of each targeted mode is normalized with the closed form solution.
f*
Closed form solution.
Modes 1 and 2 Flexural Mode 3 Torsional Mode 4 Extensional
f*
CBEAM
42.649 Hz
42.649 Hz
1.0124
f*
CBEAM
77.542 Hz
77.542 Hz
0.9157
f*
CBEAM
125.00 Hz
1.0000
Modes 5 and 6 Flexural Mode 7 Torsional Modes 8 and 9 Flexural
f*
CBEAM
42.649 Hz
148.31 Hz
1.0409
f*
CBEAM
233.10 Hz
0.8840
f*
CBEAM
284.55 Hz
1.0725
Model Files
The model files used in this problem include:
  • <install_directory>/hwsolvers/demos/optistruct/verification/fv5.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
