OS-V: 0425 Clamped Thin Rhombic Plate
Test No. FV15 The behavior of distorted thin elements in normal modes analysis is examined using OptiStruct.
fv15
図 1.
Benchmark Model
The 4-node quad elements with 12x12 mesh configuration are used to model the thin rhombic plate. The x-translation, y-translation displacements, and z-rotational displacements are fixed for all of the nodes. In addition, the z-translation, x-rotational and y-rotational are fixed for the nodes along the four edges.
The material properties are:
E
200 x 109 N/m2
υ
0.3
ρ
8000 kg/m3
Modal Analysis Results
The frequency of each targeted mode is normalized with the closed form solution. If a closed form solution is not available, the target values for H.O.E. are used instead. All benchmarked results are normalized with target values.
f*
Closed form solution
Mode 1 Mode 2 Mode 3
fv15a fv15b fv15c
f*
CQUAD4
7.938 Hz
0.9798
f*
CQUAD4
12.835 Hz
1.0079
f*
CQUAD4
17.941 Hz
1.0182
Mode 4 Mode 5 Mode 6
fv15d fv15e fv15f
f*
CQUAD4
19.133 Hz
0.9629
f*
CQUAD4
24.009 Hz
1.0339
f*
CQUAD4
27.922 Hz
1.0036
Model Files
The model files used in this problem include:
  • <install_directory>/hwsolvers/demos/optistruct/verification/fv15.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
