OS-V: 0420 Free Thin Square Plate
Test No. FV12 A thin square plate model, which contains three rigid body modes. OptiStruct investigates the repeated eigenvalues and kinematically incomplete suppressions of the thin plate in Normal Modes Analysis.
fv12
図 1.
Benchmark Model
The 4-node quad elements with 8x8 mesh configuration are used to model the plate. The x-translation, y-translation displacements and z-rotational displacements are fixed for all nodes.
The material properties are:
E
200 x 109 N/m2
υ
0.3
ρ
8000 kg/m3
Modal Analysis Results
The frequency of each targeted mode is normalized with the closed form solution. The closed form solution is not available for mode 10, use target value for H.O.E. instead.
f*
Closed form solution
Mode 4 Mode 5 Mode 6
fv12a fv12b fv12c
f*
CQUAD4
1.622 Hz
0.9964
f*
CQUAD4
2.360 Hz
1.0145
f*
CQUAD4
2.922 Hz
1.0231
Modes 7 and 8 Mode 9 Mode 10
../../images/solvers/fv12d.png fv12e fv12f
f*
CQUAD4
4.233 Hz
0.9978
f*
CQUAD4
7.416 Hz
1.0496
F[HOE]
CQUAD4
7.392 Hz
1.1746
Model Files
The model files used in this problem include:
  • <install_directory>/hwsolvers/demos/optistruct/verification/fv12.fem
Reference
NAFEMS Ltd, The Standard NAFEMS BENCHMARKS TNSB Rev. 3, NAFEMS Ltd, Scottish Enterprise Technology Park, Whitworth Building, East Kilbride, Glasgow, United Kingdom, 1990.
