Verify the complete work flow in batch mode or interactively through HyperMesh.
Verification include:
- Model setup
- New functionality
- Process consistency
- Verification of legacy scripts
Process work flow with Process Manager template verification includes:
- Verify complete work flow interactively through HyperMesh
- Model setup
- Process consistency across versions
- Verification of legacy scripts for current or previous HyperMesh versions.
Click the FE Model tab then click the Model
Setup tab.
From the File type drop-down menu, select a solver
type.
Options include:
Radioss(BLOCK), OptiStruct, Abaqus,
ANSYS, LS-DYNA,
MADYMO, Marc,
Nastran, PAM-CRASH 2G, Permas, and
Samcef.
Select the HyperWorks version number.
Activate any of the checkboxes.
Option |
Description |
Modify cmf script |
If this option is activated, it replaces all HyperWorks paths with the selected HyperWorks version and generates a new
copy(copies) of the .cmf file(s). |
Config file |
Activate this option to load a config file. |
Ref Version |
Select the HyperWorks version number of
your reference file from the drop-down menu.
Model (Solver Deck/HM File) |
Deactivate this check box if there are no models to load. Or,
activate the check box to load a solver deck model or HyperMesh file.
Add or delete any scripts/cmf files.
Select an output directory.
Click Run.
All selected scripts/cmf files are run in the (solver deck
model/
HyperMesh model) batch mode.
If no
models are selected, then the scripts/cmf files are run batch mode. In this
case, the model should be read through scripts/cmf files.
HyperMesh(hm) and solver deck files are saved to the
output directory. Click Status to browse to the
output directory.
Tip:
- The message log file displays
the current status of processes in progress. Click
Status/Diff to display the respective
report. The message log file is a text file and is saved to your
output directory.
- Click Html
Report to generate an HTML report of your
session information for any number of files run through the
process.
- You can set the environmental variables in the config file.
- If ModelSetup is 0: Execute
hmbatch.exe
- If ModelSetup is 1: Execute
hmopengl.exe
- If ModelSetupConfig is 0: Reads the config file but doesn't replace
the paths (only reads the ModelSetup variable).
- If ModelSetupConfig is 1: Reads the config file and replaces all
paths in the CMF files.
