The Compare HM Versions tab allows you to compare input/output solver files between
any two HyperMesh versions. You can also compare with a
reference file or previously certified file. This is most useful for non-HyperMesh generated solver decks.
Click the FE Model tab then click the Compare
HM Versions tab.
From the File type drop-down menu, select a solver
type.
Options include:
Radioss(BLOCK), OptiStruct, Abaqus,
ANSYS, LS-DYNA,
MADYMO, Marc,
Nastran, PAM-CRASH 2G, Permas, and
Samcef.
Select the current and reference solver
version.
Select export profile options.
Options include:
LS-DYNA, Radioss(BLOCK), PAM-CRASH 2G, Abaqus,
Nastran, Marc
Select input files.
If you select Reference File instead
of Reference Version, the GUI changes slightly. Select
Reference File to compare your file with a reference
Select an output directory.
Click Import/Export to import your source file and
output your results information.
The Current Version and Reference Version you are comparing are
listed.
Click Diff to view the report which lists
the difference between the HyperMesh current
version exported files and the HyperMesh
reference version exported file, OR the HyperMesh current version exported files and the reference file/previously
certified file.
Tip:
- The message log file displays
the current status of processes in progress. Click
Status/Diff to display the respective
report. The message log file is a text file and is saved to your
output directory.
- Click Html
Report to generate an HTML report of your
session information for any number of files run through the
process.
