Register HVPcontrol
Register HVPcontrol registers the HVP ActiveX control for HyperView Player.
  • Start Register HVPcontrol in Windows.
    1. From the Start menu, select All Programs.
      On Windows 10, go to the All Apps menu.
    2. Select Altair <version>.
    3. Select Tools > Register HVPcontrol.
      On Windows 10, select Register HVPcontrol <version>.
    A message is displayed stating that the registration was successful.
  • Manually switch to a previous or newer version of HVP ActiveX control.
    1. Using your file browser, locate HVPControl.dll, which is usually found at C:\Altair\<version>\hw\bin\win64
      Windows has a program called regsvr32 that is used to register controls. The HVP control is a 32-bit library so you would use the same regsvr32 program to register on a win64 machine.
    2. Go to Start > Run and enter regsvr32 followed by the path and name of the control you want to register.
      Place the path in quotations. For example, to register the HVPControl.dll enter:
      regsvr32 "C:\ Altair\<version>\hw\bin\win64\HVPControl.dll"
    3. Click OK.
    4. Click OK.
    5. To view a list of options for the regsvr32 program enter only regsvr32 in the run box and click OK.
      A list of options is displayed.
