ACU-T: 3110 / SL-2400 Exhaust Manifold Conjugate Heat Transfer - CFD Data Mapping using acuOptiStruct
Prerequisites
Prior to starting this tutorial, you should have already run through the introductory HyperWorks tutorial, ACU-T: 1000 HyperWorks UI Introduction. To run this simulation, you will need access to a licensed version of SimLab and AcuSolve. You will need an internet connection to watch the video tutorials and download the files.
You can work through this tutorial in 3 different ways:
  1. Complete tutorial - CAD to Results
    This provides a complete workflow starting from importing the CAD, generating mesh, and setting up the simulation to visualizing the results. To begin here, download the CAD geometry.
  2. Mesh Generation - CAD to Mesh
    You can navigate directly to the Mesh Generation section and work from importing the CAD to generating the mesh. Afterwards you can continue with the solution setup. To begin here, download the CAD geometry.
  3. Solution Setup - Mesh to Results
    You can navigate to the Solution Setup section and work from setting up the simulation to visualizing the results. To begin here, download the SimLab database.
Tutorial Video
Additional Resources
For more tutorials, please visit the SimLab Learning Center.
