udfGetNbcUsrVals()
Return the array of user supplied values.
nUsrVals = udfGetNbcUsrVals( udfHd ) ;
AcuSolve User-Defined Nodal Boundary Condition
udfHd
The opaque handle (pointer) which was passed to the user function.
Return Value
usrVals (Real*)
Pointer to one-dimensional real array of user values as given in the input file. This array has udfGetNbcNumUsrVals() entries.
This routine returns the real array of user-given parameters. The order of the parameters within the array is the same as in the input file. For example,
Real* usrVals ;
Real amp, omega ;
udfCheckNbcNumUsrVals( udfHd, 2 ) ;
usrVals = udfGetNbcUsrVals( udfHd ) ;
amp = usrVals[0] ;
omega = usrVals[1] ;
This routine expects a valid udfHd.
